1981 400 special II Headlight Wiring
I have power to the headlight fuse but nothing at the headlight. Is there something in between that could be malfunctioning?
All other lights work.
I can 't find a wiring diagram. Any ideas how to diagnose this problem?
Does it have a headlight switch? If not there is most likely a relay that powers up the headlamp when the engine reaches certain revs...like 800 or so. this si to stop battery drain prior to starting the motor.
No, it does not have a switch, there must be a relay then, but I don't know how to find it. I direct wired to the headlight from the fuse and it works again. It still starts OK, hope it doesn't cause any other problems.
Thanks for your help!
