June 20, 200718 yr hiya all first time in using the forum, i have a fzr400 and i cant seem to get the timing right...the bike will not start...can anyone tell me where the cams should be to start off with many thanks tony
February 25, 200917 yr hiya all first time in using the forum, i have a fzr400 and i cant seem to get the timing right...the bike will not start...can anyone tell me where the cams should be to start off with many thanks tony Take your valve cover off to expose the cams and chain. if you look at the end of the cams, you will see a little dot on the end. You will also see a dot on the carrage holding the cams in. Just rotate the engine via front sprocket to align both dots together. This is you default cam position.
