:blink: hiya all first time in using the forum, i have a fzr400 and i cant seem to get the timing right...the bike will not start...can anyone tell me where the cams should be to start off with many thanks
tony :D
  • 1 year later...
tony :D
Take your valve cover off to expose the cams and chain.
if you look at the end of the cams, you will see a little dot on the end. You will also see a dot on the carrage holding the cams in.
Just rotate the engine via front sprocket to align both dots together. This is you default cam position.
