June 15, 200718 yr I've recently bought a 2003 Fazer600 and find the gearbox has quite a low pitched whine in 1st 2nd and 3rd gears, it could be there in the higher gears as well but when you are up to speed you can't hear it. This is the first Fazer i've had and the first Yamaha since a 350LC in the 80's. Is it a characteristic of these boxes or can anyone give me any advice please?
June 15, 200718 yr I've recently bought a 2003 Fazer600 and find the gearbox has quite a low pitched whine in 1st 2nd and 3rd gears, it could be there in the higher gears as well but when you are up to speed you can't hear it. This is the first Fazer i've had and the first Yamaha since a 350LC in the 80's. Is it a characteristic of these boxes or can anyone give me any advice please? I've not noticed a whine on my bike, but I wear ear plugs most of the time. Paul
June 15, 200718 yr Author I've not noticed a whine on my bike, but I wear ear plugs most of the time. Paul Think I'll need to get a set as well. Thanks Paul
June 15, 200718 yr Think I'll need to get a set as well. Thanks Paul http://p196.ezboard.com/ffazerownersfrm3.s...icID=3229.topic Have a look on the FOC-U board, might be more help. Paul
June 15, 200718 yr I had a fz600, same motor as yours, mine would wine on kickstand , found that the last gear on the shaft was press-on instead of clips. the gear had come loose and was rubbing on case. easy fix just very time consumming
June 15, 200718 yr Author http://p196.ezboard.com/ffazerownersfrm3.s...icID=3229.topic Have a look on the FOC-U board, might be more help. Paul Thanks again Paul I'll have a look
