Sorry if some of this doesnt all make sense. New to the bike world. had a top end rebuild on my TDR 125 a couple of weeks ago. After this it began to leak water. Got the barrel and head skimmmed and put in a new gasket set. Bike ran perfectly for about 250 miles after this but yesterday it started to over-heat really quickly. Checked coolant level seems perfect, not airlocked and isnt leaking water from anywhere. Noticed a black oily residue on the bracket near the chain. I cleaned this off to see if it was a fresh leak but after driving there doesnt appear to be any more leak. Pipes around the radiator are hot which i think means that the water is circulating!?
Any help or suggestions greatly appreciated
Cheers
Sticking thermostat? Siezed or broken water pump? How do you know it's overheating?
[/quote
It has a tempature gauge. thermostat wasnt opening, took it out and problem solved. Need to get a new one now.
Thanks for the suggestion
