Posted June 10, 200718 yr have been trying to get the timing right and im just not getting it ive done it three times now am only getting fire on number 1 cylinder plus backfiring somebody help please
June 10, 200718 yr Hmm, when my XJ750 did that it was because I had the plug leads on wrong. I had 1&3 together, and 2&4 when it ought to have been 1&4 and 2&3. Might be worth checking, what bike is it?
June 10, 200718 yr Author Hmm, when my XJ750 did that it was because I had the plug leads on wrong. I had 1&3 together, and 2&4 when it ought to have been 1&4 and 2&3. Might be worth checking, what bike is it? tried it wasn't that I've done the timing three times how bout this the timing plate mark has more than one line with the T beside them to the right exactly what line is the mark and which stroke is tdc on
June 10, 200718 yr Moderator tried it wasn't that I've done the timing three times how bout this the timing plate mark has more than one line with the T beside them to the right exactly what line is the mark and which stroke is tdc on on my xs400 the timing marks are called RF for right LF for left. The LT/RT etc is for the valve timing. just a thought
June 10, 200718 yr Author on my xs400 the timing marks are called RF for right LF for left. The LT/RT etc is for the valve timing. just a thought there's a t with two or three lines to the left tdc is supposed to be at the t but there's no lines on the t itself
