June 8, 200718 yr i just bought a new 2007 fazer 1000 and i have bought a scot oiler. The web site shows a nice picture of the pipe that i need to connect the vacuum t piece into. trouble is that i cannot find a pipe that looks like this. Do i need to take a panel off or remove the tank? I dont't want to go removing stuff just to look for this vacuum pipe, so and more specific instructions would be appreciated. Thanks in advance, Peter PS the 2007 fazer is fixed, the throttle response is loads better than the 2006 model i tested.
June 8, 200718 yr All the vacuum hoses are likely to be on top or around the injectors and other parts of the engine, which means it's a tank and airbox off jobby. Shouldn't be too much of an issue as most bikes have similar ways of keeping them in place. Regards
June 9, 200718 yr Author ok, thanks for that. I found it just underneath the petrol tank. at the seat side at the bottom. Peter
