Frank Johns Posted June 5, 2007 Share Posted June 5, 2007 Recently obtained a 78 DT100 that had been sitting for a year. Wouldn't start with out priming it then it would die, so I cleaned the carb. Now, it will still only start if I prime the carb. And once it starts it idles at full bore and, of course, smokes terribly. The idle adjustment seems to have no effect, and as far as I can tell the throttle cable isn't stuck. What's my next step? Thanks. Link to comment Share on other sites More sharing options...
Paul Mc Posted June 6, 2007 Share Posted June 6, 2007 Recently obtained a 78 DT100 that had been sitting for a year. Wouldn't start with out priming it then it would die, so I cleaned the carb. Now, it will still only start if I prime the carb. And once it starts it idles at full bore and, of course, smokes terribly. The idle adjustment seems to have no effect, and as far as I can tell the throttle cable isn't stuck. What's my next step? Thanks. My guess is the tickover is way too high, screw it completely in and then out a turn or so, try again. (Had the same thing with my AG100 (DT100) a while ago). Paul (Swindon) Link to comment Share on other sites More sharing options...
aunty Posted June 6, 2007 Share Posted June 6, 2007 Recently obtained a 78 DT100 that had been sitting for a year. Wouldn't start with out priming it then it would die, so I cleaned the carb. Now, it will still only start if I prime the carb. And once it starts it idles at full bore and, of course, smokes terribly. The idle adjustment seems to have no effect, and as far as I can tell the throttle cable isn't stuck. What's my next step? Thanks. I would take that carb off again and go through it all step by step, making sure its all set up ok, and evrything is moving where it should be, then check the inlet rubbers are done up tight and haven't split as that would let in too much air. also make sure that your choke isn't getting stuck, i'd bet that'll sort it Link to comment Share on other sites More sharing options...
Frank Johns Posted June 7, 2007 Author Share Posted June 7, 2007 I would take that carb off again and go through it all step by step, making sure its all set up ok, and evrything is moving where it should be, then check the inlet rubbers are done up tight and haven't split as that would let in too much air. also make sure that your choke isn't getting stuck, i'd bet that'll sort it I figured going through the carb again would be be the next step (unfortunately). Thanks!! Link to comment Share on other sites More sharing options...
Frank Johns Posted June 7, 2007 Author Share Posted June 7, 2007 Off to the mechanic, so see what he does. Link to comment Share on other sites More sharing options...
