June 1, 200718 yr Hi folks first time on forum, Quick question just bought 2000 xjr 1300 and gear selection is a bit ropey, sometimes wont select next gear up or down first time needs two touches, is this a quirk or is it selector or summit else any thoughts before i put into garage.just came from virago so learned that all clunks and clangs is not a malfunction it is bike quirk cheers sooty
June 1, 200718 yr Hi folks first time on forum, Quick question just bought 2000 xjr 1300 and gear selection is a bit ropey, sometimes wont select next gear up or down first time needs two touches, is this a quirk or is it selector or summit else any thoughts before i put into garage.just came from virago so learned that all clunks and clangs is not a malfunction it is bike quirk cheers sooty hi m8 welcom to the wonderful world of xjr's i have one a 1300 sp year 2002 and find the gear change no problem at all. if i was you i would join the owners club, it has all the help you will ever need for your xjr, the site is down at the mo, but once up ask sharky for any of your xjr needs ok here's the link below, don't forget it's down at mo, should be up soon i hope. http://www.yamahaxjrownersclub.com/mx/index.php
June 2, 200718 yr Author hi m8 welcom to the wonderful world of xjr's i have one a 1300 sp year 2002 and find the gear change no problem at all. if i was you i would join the owners club, it has all the help you will ever need for your xjr, the site is down at the mo, but once up ask sharky for any of your xjr needs ok here's the link below, don't forget it's down at mo, should be up soon i hope. http://www.yamahaxjrownersclub.com/mx/index.php cheers for the heads up will try later sooty
