Posted May 30, 200717 yr Steering damper What are they and do i need one on my bike? Ive got 2000 R6-heard alot of people fittin them to this bike why?
May 31, 200717 yr It's basically a piston that improves the bikes stability (pretty much eradicates tank slappers) but can make the low speed steering a little heavy. If you ride your R6 hard then it's a worthwhile investment.
June 1, 200717 yr It's basically a piston that improves the bikes stability (pretty much eradicates tank slappers) but can make the low speed steering a little heavy. If you ride your R6 hard then it's a worthwhile investment. Would you recommend for an R1 also?
June 1, 200717 yr Would you recommend for an R1 also? I honestly don't know fella as I've never ridden a R1. If you drive everywhere at 90mph then it's definitely not going to do any harm. My new bike has one fitted as standard and compared with my old R6 (with no damper) it feels far more solid through bends and over bumps.
June 1, 200717 yr Author I honestly don't know fella as I've never ridden a R1. If you drive everywhere at 90mph then it's definitely not going to do any harm. My new bike has one fitted as standard and compared with my old R6 (with no damper) it feels far more solid through bends and over bumps. Are they easy to fit booze? Does the suspension have to be set up by expert? Im a novice mind!
June 1, 200717 yr Are they easy to fit booze? Does the suspension have to be set up by expert? Im a novice mind! Aye fella, piece of bun. Took me about an hour when I was hungover. You need to remove the big nut in the centre of the handlebars though so make sure you have a spanner big enough - I got mine from Halfords for a tenner.
June 2, 200717 yr Would you recommend for an R1 also? DEFINITELY.......... personally i wouldnt ride an R1 hard without 1. Ive got a side mounted Ohlins damper on mine (they are supposed to be on the Yoke Ducati style), but better mounted to the frame and fork leg, due to less moving parts. And Yanto, they are a peice of piss to fit, and you dont need to touch the suspension. When you fit the damper (after following instructions carefully) you can set the damper up yourself. They usually have a dial or knob, that adjusts the stiffness of the damper, the harder its set, the more stable it is when your riding hard, but harder to steer at slow speeds, so its just a case of finding the inbetween that your comfortable with. Hope all that helps????? Steve
June 4, 200717 yr I must admit i went out for a blast with a couple of mates yesterday and they were on a GSXR750 with damper and a ZX6R without and the mate with the damper was much smoother over the bumps, where the riders without dampers me included couldnt get comfy and didnt have as much confidence through the corners as the bumpers were really taking their toll! After this weekend i am definately looking into them for my R6!!
June 5, 200717 yr What steering dmapers do people use adn what are recommended??? What things are best to look out for in them???
