1986 DT200
Hello
My friend has a 1986 DT200 and the inner right hand side case cracked at the kickstarter ear i need to find a set of cases or just the right inner case.
Thank you for your help
  • 1 month later...
I would try to repair it with some J.B. Weld they have it in canada dont they? clean it sand it clean it jb weld it your only out $2.99 US if it doesnt work but if done correctly it may get you going untill you find you new or used part. Good luck
