CLUTCH LINE LUBRICATION?
My clutch is getting very hard, dose any body know of a lube to use in the line from the handlebar to the box?
If its just a cable operated clutch, then just use a bit of engine oil, the thicker the better!
I use carb cleaner to clean any muck that's built up in the cable housing....
Then a good healthy dose of Silicone Spray on ALL cables..........works a treat. ;)
the trouble with that is, carb cleaner may take away the remainder of the grease thats in there, and any lubeing will be less effective as the grease should aid it from draining away :D
