R6 Low Rev Problems
Hi Just got a 2000 R6 which runs rough at low revs I have too rev it hard to pull off or the engine stuters and stalls but runs OK at higher revs.
I thought thjis was the carb but after a service I was told the bike is producing too much compression.
And (Dont understand this bit) isnt clearing the oil way properly?? does anyone know what would cause the problem and how to cure the problem.
Do you wash it wish steam cleaner cos it sounds like there is water in the coils which caused a similar problem for my bike.
Regards
Regards
no didnt steam clean it but garage says it has too much compression?? I didnt think you could have too much compression
hi i had the same prob it was a small split in one of the carb to engine rubbers
would this cause too much compression but ill have a look thanks
hi i'm new to the site and i have a 1999 r6 and i have the same problem can anybody help.
i've changed the plugs but the only thing i've noticed is the carb to the left is soaked with fuel when i take the air filter off.
could this be just the carbs need setting up or somethin else.
and help would be appricated
stu
