when i start my bike (77 xs360)
i dont usually have my choke on all the way
if i do, it take it to about under half as soon as i get the bike started
as the bike warms up, the idle may rise slightly
but as soon as the bike is warmed up and i take to choke off all the way
the idle slowly rises to about the 3k range
any ideas?
thanks for your time
and thank you drewpy
for your past help
and ill thank you ahead of time
and your help on this matter
any ideas?
for your past help
You're running too lean, screw in the air screws on the front of the carbs by equal amounts. If that doesn't help you need to check your connections from carb to cyl head and maybe look at buying new carb inlet rubbers as they crack with age and petrol (gas)
thank you sir for the information
i will go check it out
i believe that my inlet rubbers are in good condition
so i will start with the air screws
then check for leaks
then check the inlets again
if i run into more problems ill be back
if it fixes everything ill be back to thank you again
anyway
THANKS AGAIN!!!
