SPEEDO PROBLEM
Hi guys, this is one ive not seen before, my speedo fluctuates when i am riding, if traveling at 75 mph the speedo needle will drop to 60 or so then back up to 75, then it may drop to 30 ish and back up again. i`m suspecting the spedo cable (if you can call it a cable) but not 100% sure. Any ideas?
The cable would be the likely suspect in my view
But it could just be the the cable end has vibrated loose & is about to fall off the back of the speedo?
Had that 1 happen a few times to me......especially riding a Big Thump. ;)
