Indicators
pockethook
This post is 6331 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Can anyone think of a way to get 10mm thread indicators into 8mm holes?
Also is there a good way to attach a bulb to a headlight without a bulbholder?
easiest way is to drill through the 8mm holes with a 10mm drill ! as for the bulb, plug it in to the wiring loom then slide it to where you think it should go, then try to figure out what you can do from there. mybe make a template from cardboard, then you can try making something a bit more sturdy from there.
