I have an 86 XT350, I had the motor rebuilt, and with that the timing chain was replaced, along with the valves. The problem I have is, the motor seems to have a top end rattle. It sounds like a timing chain, or valves to me, but I am reasured by my mechanic that all it tight and in adjustment. What else could be making this noise? Is it a common noise for these bikes? It seems to have all the power it should, and starts and runs fine.
Check your cam chain tensioner isnt to going faulty.
Is there a way to check this with out taking the motor apart?
Yes sure just unbolt it from the back off the cylinder and apply pressure on it,if it moves from
the position its(goes back) then its faulty and will let pressure off the cam chain which in turn will
let your cam chain slip on the cam shaft wheels and then bent valves,this is what happend to my XT350.
Thanks now I might know why the valves just bent in mine last year.... I will see if my mechanic looked at that.. I will play with it this weekend, and see if I can get it to move.
Thanks again for your help.
No problem Quack just hope it helps,as far as remember the new cam chain tensioner i bought
wasnt that expensive.
