Posted April 21, 200718 yr HELLO CAN ANY ONE HELP ME OUT I HAVE GOT A XS400 CHOPPER WITH A SAD LOOKING NARROW REAR TYRE (100x90x18) I DONT WANT TO GO STUPID BUT WHAT IS THE BIGGEST TYRE THAT WILL FIT WITH OUT TO MUCH BUGGERING ABOUT THE WHEEL SIZE IS 2.15X18 ANY INFO IS GOOD INFO THANKS
April 21, 200718 yr Moderator HELLO CAN ANY ONE HELP ME OUT I HAVE GOT A XS400 CHOPPER WITH A SAD LOOKING NARROW REAR TYRE (100x90x18) I DONT WANT TO GO STUPID BUT WHAT IS THE BIGGEST TYRE THAT WILL FIT WITH OUT TO MUCH BUGGERING ABOUT THE WHEEL SIZE IS 2.15X18 ANY INFO IS GOOD INFO THANKS The bigest size I have seen is 120x90x18 (on a spare wheel I had) but you fit it at your own violition and I am not recommending it per se!. I am running on 90/90/18 front and 110/90/18 rear btw writing in uppercase is considered rude, as you are shouting!!
April 22, 200718 yr Author The bigest size I have seen is 120x90x18 (on a spare wheel I had) but you fit it at your own violition and I am not recommending it per se!. I am running on 90/90/18 front and 110/90/18 rear btw writing in uppercase is considered rude, as you are shouting!!
June 24, 200717 yr Author Hello just to let you know i have just fitted the bike with a back wheel off a xs 650 tyre size 130. 16. and it looks a hole lot better so i have stripped the bike down for a rebuild .
June 25, 200717 yr Moderator Hello just to let you know i have just fitted the bike with a back wheel off a xs 650 tyre size 130. 16. and it looks a hole lot better so i have stripped the bike down for a rebuild . great, that wheel is off a custom model
