April 11, 200718 yr Hi, I was wondering if anyone else had this problem. For some reason my Fazer 600 (2004 model) break light does not switch off. Neither the front or rear brake is engaged so I suspect the sensor is gone. Any idea where this sensor is located on the bike? Thanks, Nico
April 11, 200718 yr Author I managed to find the problem, the piston sensor behind the footbrake didn't return to its normal full out position. A simple adjustment to it solved the problems. Nico
