dt wheel swap
Hi. Does anyone know if the rear wheel from the 77-ish xt500 (with aluminum rim) or even the later-model dtmx rear wheel (also with aluminum rim) will bolt onto a 75/76 dt400 (which comes stock with steel rim)? The wheel bearing ID is the same. I understand that the monoshock dts have a different brake backing plate but a xt one (and maybe one from a 75/76 dt as well) will likely fit. Any help will be appreciated. Thanks.
