1982 650 Maxim Help
Heres the deal.
Ive got a perfect 1982 Yamaha Maxim 650. Just had to replace the head unit bearings, due to this problem of a dented race, making the steering "center" itself. Trust me its a disconcerting feeling.
Ive always wanted a little more braking power; so I thought I'd ask the guru's on here whether you know of anyone that has done a mod to the 650 to utilize a dual front brake system. I know the Seca has dual front brakes. Can the shocks from the Seca be swapped out to the Maxim??? Maybe the 750 Maxim/Seca will work.
Can you just swap the shocks out, or do you have to do the entire triple tree?
I bought this Maxim new in 1983 and watched them put it together. We've been through a lot together and Im not ready to get rid of it. Just need some upgrades.
Also, I know there is a simple mod to turning the "always off" blinker lights to "always on" running light/blinker lights. Anyone got an easy step-by-step for this mod?
Mike (Mickey)
I believe the rear shocks are not the same length between the Seca & the Maxim.....I've had both ;)
Although the front forks/brakes should swap out without a prob.
But, better yet....& cheaper too, is just to upgrade to a steel braided line & some EBC pads.....makes a Helluva difference in feel! ;)
