yz125 88-89
morning all....
need your help if you dont mind.
i have a 1989 yz125 and the barrel is fu*+ed to be honest with ya. i also have an 88 engine which is immaculate and on standard bore! (jap import) but it aint got a stator plate or flywheel........ will the stator and flywheel from my 89 engine fit and more importantly work in my 88 engine??? if not can i use my 88 barrel/piston/head on my 89 engine???
hope i didnt confuse you too much, any help/advise will be great.....
cheers :D
stator and rotor fit and works fine. kicks over first time every time :D ......... however, the cylinders are slightly different! the exhaust port on the 89 is central and on the 88 its slightly to the right(looking from the front) so i need an 88 front pipe :unsure:
