March 23, 200718 yr morning all.... need your help if you dont mind. i have a 1989 yz125 and the barrel is fu*+ed to be honest with ya. i also have an 88 engine which is immaculate and on standard bore! (jap import) but it aint got a stator plate or flywheel........ will the stator and flywheel from my 89 engine fit and more importantly work in my 88 engine??? if not can i use my 88 barrel/piston/head on my 89 engine??? hope i didnt confuse you too much, any help/advise will be great..... cheers
March 25, 200718 yr Author stator and rotor fit and works fine. kicks over first time every time ......... however, the cylinders are slightly different! the exhaust port on the 89 is central and on the 88 its slightly to the right(looking from the front) so i need an 88 front pipe
