I've owned a 2004 TT600R for the last year. I use it for commuting approx. 20miles 3 or 4 times a week. It always sounds laboured when starting although once started it runs fine. I've just had a full service but this has done nothing to make it a more confident starter. It's worse in winter and if left for more than a week it's touch and go whether it'll start at all. It's only got 6k on the clock.
I'm aware that previous/original models were fitted with a kick start. Is anyone aware whether or not it's possible to fit an e start 2004 model with an aftermarket kickstart? I'm not too mechanically minded being limited basics servicing etc. Any ideas would be appreciated.
If there's a provision for a kickstarter on the right side engine case (usually blanked off).....
I think you can buy the whole assembly from Yamaha :unsure: .....which should only require the removal of oil & that right side case with minimal tools, to install......not too tough really. ;)
My brother's got a DR650 & looking to do this same mod.
