2000 yamaha blaster clutch help
hey everyone im kinda new to this site and i made a account so i could ask you all whats wrong with my clutch
so heres the problem.....
- when i start it up i let it run for a few seconds i take the choke off then i go from nuetral to 1st. with the clutch engaged and it jumps and stalls out ..i adjusted the clutch many of times...but after that it happens sometimes or not enough to stall out let me know what you think maybe it could help me out
I assume you mean disengage the clutch as if you don't this would be the cause of the problem. If you are doing everything correctly it sounds like you may need to overhaul the entire clutch mechanism or at least clean it as the plates maybe sticking.
Regards
