Hi every1 am new 2 yamaha club & am lookin 4 sum advice on how 2 d-restrict my new dtr its an 06. All Ideas r welcome.
:welcome: to the forum Chris
For starters.....you'll need to pull off the exhaust & remove what looks like a big flat washer that's placed just inside either the exhaust port or the leading end of the pipe.
Hope this helps ;)
hello
was looking intio buying a full power one for myself...... but they dont exist .....whilst speaking to the yamaha tachnician he told me the only restriction is in the exhaust.... but theres a catch ....... they have got wise to the easily removable tacked in restricors that sit just inside the downpipe and have put the restrictor around in the bend so to speak
the solution is either get proffesional help in cutting open the pipe locating the restrictor remove it and then weld up ... there is a problem with this though...... it looks obvious that the exhaust has been tampered with !
I think the best option is to buy an aftermarket front pipe ....thus preserving your original .... why is this good.......... well for two reasons.... first reason you can always put your bike back to standard before you seel it if needed preserving that ORIGINAL look
secondly an aftermarket pipe doesnt look tampered with '' i brought it like that officer'' you get the jist
This is important after liberating the potential from your machine you MUST jet up the carburettor to take into account it will be breathing more free.....failure to do this and your piston/top end will be goosed in minutes
hope this helps steve
hello
Thanks For da tip.
Have just had a dep fitted & it makes a massive difference. have orderd some new jets but it seems to run ok on the original one's.
You ought to get that airbox snorkel off too if you want it derestricted. Whip off seat, you'll see a rubber tube like a bung. Just pull it off and refit seat.
