January 4, 200719 yr I need to know what the differences are between the 92 and 94 FZR600R. I am looking at two different bikes that can be combined to make one awesome bike and have a few parts lying around. The big piece is if a tranny from a 92 will work on a 94. If there are any little details like the wiring harnesses are different, that will be very helpful to know. Thanks
January 27, 200718 yr I need to know what the differences are between the 92 and 94 FZR600R. I am looking at two different bikes that can be combined to make one awesome bike and have a few parts lying around. The big piece is if a tranny from a 92 will work on a 94. If there are any little details like the wiring harnesses are different, that will be very helpful to know. Thanks Hi xjwoods, The only difference I know of is that the '92 has a different top fairing and a single light where the '94 has the same top fairing and the dual headlights that the original FZR600 had. Only '91 and '92 had the single headlight. Everything else I think should be the same, unless I'm mistaken. I believe they are mechanincally identical. Had a '93, Great bikes!, weak suspension. Progressive fork springs, a Dynojet kit and a Supertrapp slip on made a huge difference. Rear shock was barely good enough. Good luck with the project!
