August 24Aug 24 Moderator On 23/08/2025 at 17:03, AMB said:Center stand does not seem big enough to hold the bike properly, will fudge it for now with a bit of wood.I expect once the bike is done I will just stick with the side stand and take it off.they have always been marginal at best. Think I welded a plate under each one after checking the pivot wasn't worn
August 29Aug 29 Author Morning.The starter motor was not engaging properly so I have taken the alternator cover off for a look see.There apears to me mucho slack in the starter chain, is this normal?I have about 15mm of slack? :(Or shall I just do away with the electric starter altogether.
August 30Aug 30 Moderator Is it actually adjustable? I'm not sure if it will make much difference.My eyes ARE however drawn to your primary drive. That's a LOT of wear. You need a new drive chain (primary, chain, secondary)..!
August 30Aug 30 Author 41 minutes ago, Snakebite68 said:Is it actually adjustable? I'm not sure if it will make much difference.My eyes ARE however drawn to your primary drive. That's a LOT of wear. You need a new drive chain (primary, chain, secondary)..!Yeah It's a job to be done when the engine is back in the bike.59 minutes ago, Snakebite68 said:Is it actually adjustable? I'm not sure if it will make much difference.My eyes ARE however drawn to your primary drive. That's a LOT of wear. You need a new drive chain (primary, chain, secondary)..!
August 31Aug 31 Author Replaced the front indicators this morning and sorted the speedo.Now tackling the switch gear, kill button was not working and the starter button was missing.Lucky I have loads of spares that came with the bikes.Waiting for front caliper seal kits x two, then I can get the front brakes working.Tony.
September 13Sep 13 Author Right, it's time to get back to work.Engine is back in.Wiring, carbs, exhausts,chain, claen and polish to go.
September 17Sep 17 Author Slowly getting the heap back together.Want to refoam and cover the seat to try and slim it down a touch.Would also like to lower the rear end a touch, that huge gap between the tyre and the mudguard...yuk.
Thursday at 18:405 days Moderator Looking good...I'm not sure I'd lower the back end. It's that height for a reason.Before lowering it, see if you can find a way to 'hide' the gap...Maybe some custom textile/leather paniers?
Thursday at 23:315 days Admin On 29/08/2025 at 20:09, AMB said:Morning.The starter motor was not engaging properly so I have taken the alternator cover off for a look see.There apears to me mucho slack in the starter chain, is this normal?I have about 15mm of slack? :(Or shall I just do away with the electric starter altogether.The slack should be between 5-7mm, looks like you need a new chain and sprockets for the starter. It's probably rattling already, and may risk jumping which could crack the housing.
Friday at 19:134 days Moderator Also, we want bigger pictures!The thumbnail is the same size as the picture!!! lol
Saturday at 15:024 days Author My bigger pictures are too big to upload on here.Anyway.Getting on with the wiring and refurb of the instrument binacle.Air filters fitted and the side panels plopped on...for now.Tank temp fitted, waiting for new silencers and chain and sprockets at the moment.
Sunday at 16:203 days Author I took pictures of the pirana electronic ignition wiring, but I am still a bit confused.any instructions out there for this.got all the electrics working, just cant get the engine to fire.
Sunday at 19:522 days Moderator 3 hours ago, AMB said:I took pictures of the pirana electronic ignition wiring, but I am still a bit confused.any instructions out there for this.got all the electrics working, just cant get the engine to fire.I have ABSOLUTELY no knowledge on these things and got confused quickly, but all I got is: it all depends on what year it was manufactured (and possibly other criteria)...
Monday at 15:072 days Author Sorted.I had the wiring right, but one bullet conector was not home tight.Re did the join and she fired second kick, BRAAAAAAM!!!!!. bit loud with no silencers...sorry neibhours. ;)
Monday at 16:452 days Moderator 1 hour ago, AMB said:Sorted.I had the wiring right, but one bullet conector was not home tight.Re did the join and she fired second kick, BRAAAAAAM!!!!!. bit loud with no silencers...sorry neibhours. ;)Happy days, well done
Monday at 18:501 day Author Why is there soooo much wire to squese into the headlamp shell...sheeesh.
12 hours ago12 hr Author Fitted rear indicators and finished the wiring yesterday.Everything works which is unusual for me.Waiting for some parts now, so I am off to weld up a lounger frame.
