As a follow on from my post in classic bikes, here is the first rebuild blog.
As it arrived.
Fiddled and fluffed around for a coupke of hours and got it running, not well but it works.
Running.
Today I stripped the carbs off ready for cleaning and took out the battery box.
Tomorrow I hope to start a bit more of the strip down.
Tony.
  • Replies 46
  • Views 11.1k
  • Frame being painted. Can't do anything with it now for 48 hours while the paint hardens. Tony.
  • Today we have been maily doing. Front forks. Yolks and bearings sorted. Polished up the fork legs and fitted them along with the headlamp brackets. Next job is front mudguard and centre stand, th
  • Snakebite68
    Snakebite68
    Is it actually adjustable? I'm not sure if it will make much difference. My eyes ARE however drawn to your primary drive. That's a LOT of wear. You need a new drive chain (primary, chain, secondary).
Posted Images
I got 3 spare sets in the bits pile as well.
After some tree pruning this morning and a nice coffee and belgium bun, yum yum, I made a start.
Crap silencers and down pipes came off, not sure what to do to rectify this mess.
But anyway coils came off next, followed by the luminition box and wiring.
Then the front crash bars, foot rests, brake and gear lever pedals.
Lots of bolts later and some swearing and the engine is out and on the floor.
I will continue stripping the frame down when it gets cooler.
Tony.
hopefully the photos will help you reassemble the bike in due course lol.
just joking 😄
I take loads of pictures and store them on the pc in their own folder.
always useful for when the memory plays up on re asembly.
Todays little jobs.
Started stripping aall the rear mudguard off.
Then took off the rear shocks, chainguard and took out the rear wheel.
If I get a chance tomorrow, the front end will be coming off.
Tony
amb, it may be pragmatic, and cheaper, to make one good one? the more stock the greater the value. just musing 😊
Oh the black one will be staying stock.
This one on the other hand will be tweeked a little.
Anyway, I have finished the stripping down.
Need to clean all the muck off the frame next, then I can finish the strip and get the frame ready for paint.
What degreaser do people use these days.
Tony
Not what you'll be wanting, but since I work in a forklift repair shop, I use our giant parts washer..! 😁😎 lol
Who knows what's in the fluid, but it's at least part Paraffin...
I ended up using a mixture of petrol/gunk and a stiff brush.
Then I pressure washed the whole lot off, then cleaned the fence afterwards. ;)PXL_20250816_121738135.jpg
Some rust and a couple of small holes to weld up.
Tony.
not too bad really
Tony.
Looking good, but I would have considered taking the swingarm off, how are the bearings?
Swingarm bearings are great, no slop or play in them at all.
Started cleaning up and putting bits back on the frame.
Not going to be a pristine restoration but a minor refurb.
Tony
Fairy Snuff..! 😁
Front forks.
Next job is front mudguard and centre stand, then I can lift it down and fit the wheels.
Tony
Wheels cleaned and fitted.
Center stand does not seem big enough to hold the bike properly, will fudge it for now with a bit of wood.
I expect once the bike is done I will just stick with the side stand and take it off.
