Posted July 14Jul 14 Admin Hey all, it's finally happened!Yamaha recommends torquing the rear axle nut on the MT-09 to 108 lb-ft, which honestly seems pretty excessive. I’ve always stuck to 100 lb-ft using a proper calibrated torque wrench and I’ve still ended up with some thread wear on the axle and nut. I went to tighten the wheel and I had that horrid feeling of realising it turned to infinity.From what I’ve seen online over the years and now finally experienced myself, that high torque might be fine the first time with brand-new parts, but it’s not good if you’re adjusting your chain regularly. I think most of us are loosening and tightening the axle fairly often, and that kind of repetitive stress seems to slowly wear things down.I've learnt from this, as it's completely my own fault still, a 7 year old bike and I've never changed those parts.What I’m planning on doing now:Torquing to 95–100 lb-ft max, and that’s only if the threads are clean and in good shape.Swapping out the axle nut every once a year.If I use a bit of anti-seize, I will drop the torque a bit more maybe 90–95 lb-ft.So, when should you replace the Axle?I've researched this and can't find an actual recommendaion, I guess if the threads are still clean and not damaged, you can probably get years out of it, seems like 7 :)But if the nut doesn’t go on smoothly or you see any flattening, galling, or metal flecks… it’s probably time to bite the bullet and replace the axle. I’d now going to take it out and check it once a year.Curious to hear what others are doing with your bike, anyone using Loctite and going lower?
July 21Jul 21 Author Admin Well, it all went downhill after changing the axle.Went to start the bike up afterwards, turned over fine, but wouldn’t fire. Cranked plenty, but just no start. I had a feeling it might’ve had some water ingress, as I’d washed it before working on the axle.Pulled the tank and airbox off, everything looked bone dry. Took the coils off just in case, also completely dry. Put it all back together and tried a few wide-open throttle starts to clear any flooding. Waited a few minutes and tried again normally... pt pt pt bang stop. It almost started.Hooked up the OBD reader, no stored fault codes.Then, suddenly: click click click. Wouldn’t even try to crank. Thought maybe the battery was on its way out, so I charged it for a couple of hours, full charge. Still just click click click. Figured maybe the starter fuse had blown. At that point I gave up and booked it in with the local bike shop.Garage called later. They wanted to know a bit more history, said they weren’t 100% sure what happened, but they got it started using an external battery. No idea why it wouldn't start with me.But then they asked me something worrying: “Has it been overheating?”Not that I know of. Then again, I only ride it 30–40 minutes at a time commuting, so if it had a slow overheating issue, maybe I never noticed. They told me the coolant hoses were collapsing, and that with the radiator cap off, coolant shoots out when you rev it.They compression-tested all three cylinders, all came back fine. So now I'm hoping it's just the head gasket, and not a warped head or cracked block. It's only done 23,000 km, so hoping it’s repairable.A sad weekend for sure.Down 2hrs diagnostics so far.
July 21Jul 21 hmm...sounds a worry. please say how you get on - initially seemed an electrical issue and now something to do with the coolant, quite odd really.
August 14Aug 14 Author Admin Well bike is all back and working normally. Sorry haven't had time to come back and update.The MT does not have reinforced hoses from the water pump, so it turned out to be normal behavior and it was nothing to worry about. Guess this is an issue when you take your bike to a non yamaha garage. I've since read online of people fitting aftermarket anti collapse hoses. But from playing further it doesn't collapse enough at low temperature to cause an issue, and once at temperature and the thermostat is open there isn't an issue. Strange that they'd save a few $ and not have anti collapse hose.As for the problem they have no idea, the ECU showed ignition coil issues and it stalling. They reset the ECU and it was fine. No idea what caused the issue or in fact what it was. Had to change out the plugs as one had failed, over heated in dry engine trying to start it so much.Next job I keep putting off is a whining bearing noise which has been getting worse over the last few months. I'm hoping it's just the rear wheel bearing and not the output shaft. Guess that one will be a massive job if so.The tilt sensor was from an accident I had last year. Surprised Yamaha didn't clear this when it was being repaired.
August 15Aug 15 at 193 kg (wet weight) the MT09 is quite a light bike for the size I see. Roughly how many miles have you got on yours now please?
August 25Aug 25 Author Admin On 15/08/2025 at 16:28, Snakebite68 said:Nah, wheel bearings are easy to do... IF you get them early! lolThe wheel bearings are easy to do, I'm just not entirely confident it's not the output shaft bearings. Fingers crossed it's the wheel bearings.On 15/08/2025 at 18:47, Mr Bignel said:at 193 kg (wet weight) the MT09 is quite a light bike for the size I see. Roughly how many miles have you got on yours now please?Just coming up to 25k now, that's KM. I was thinking normal lifespan would be 40-50k. I do ride my bike in all weather though and Sydney can be very humid which could have accelerated wear.
August 25Aug 25 Moderator 14 hours ago, Alex said:The wheel bearings are easy to do, I'm just not entirely confident it's not the output shaft bearings. Fingers crossed it's the wheel bearings.I thought my output shaft bearings were going a couple of years ago. There was quite a bit of trepidation..!Turns out I needed a new chain... ... lol
August 25Aug 25 Author Admin Yeah I'm scared to take it for the next service, and can't be assed to take the chain off and spin the wheel to check.I've tried pulling the clutch in when riding and the sound doesn't appear to change that much, so hopefully it is the wheel bearing.
August 26Aug 26 Moderator The chain is still moving if your back wheel is...Take that chain off and spin it up!
August 26Aug 26 Author Admin True but there is less force on the output shaft as much lower torque. I was hoping I may hear a difference to identify the fault, but windnoise and bike noise make it too hard.
August 28Aug 28 Moderator Try lifting the back wheel, get someone to lean on the front end, put it in gear and rag the wheel round with your foot.That should put a bit of strain on it.
