December 18, 200619 yr i have unbolted the top mounting but the with the bottom mounting i have removed the split pin and tryed taping out the pin to remove the suspension but it will not move even when i have used wd40 on it can anyone give my any advice please
December 19, 200619 yr Moderator i have unbolted the top mounting but the with the bottom mounting i have removed the split pin and tryed taping out the pin to remove the suspension but it will not move even when i have used wd40 on it can anyone give my any advice please has the pin got a hex head. could try turning it to loosen up a bit. the only way i've been able to remove stubborn things like that are heat (watch for rubber melting) using a blow torch/small butane torch/heat gun/steaming hot water!! the idea is the metal expands around the pin making it easier to remove. hope that helps
December 19, 200619 yr Author has the pin got a hex head. could try turning it to loosen up a bit. the only way i've been able to remove stubborn things like that are heat (watch for rubber melting) using a blow torch/small butane torch/heat gun/steaming hot water!! the idea is the metal expands around the pin making it easier to remove. hope that helps thanx for the advise, i'll give it a good try. thanx again
