Posted May 17May 17 Hi I'm having problems with the carbs that I have on my 1991 xj 600 when stripping the carbs to put them in a ultra sonic cleaner one of the carb body's cracked. Now I'm having problems getting a replacement set could I fit a different set of carbs from a different model bike
May 17May 17 Moderator What is your exact model of bike?3KM5 999A3KM5 999B3KM6 999A3KM6 999B3KN3 999A3KN3 999BEdit/Actually, ignore all that, it doesn't seem to matter...Yamaha XJ600 (3KM5, 1991) 999 A 1991 CARBURETOR supplied next day (UK only) by Fowlers PartsWhich carb was it from that diagram?
May 30May 30 Moderator I may have an old set from a burned out bike, bodies might be ok.I'm away atm and back sunday evening but off work next week if you want me to look
June 1Jun 1 Author Hi drewpythat would be great if you have some carb bodies I'm mainly after the number three carb body as its cracked.
June 3Jun 3 Moderator On 01/06/2025 at 20:23, mozpdragon said:Hi drewpythat would be great if you have some carb bodies I'm mainly after the number three carb body as its cracked.ok, let me have a gander. weathers been shite atm
Friday at 14:034 days Moderator i PM'd you ages ago and thought you were sorted.I took photos and just need to WhatsApp the photos if you PM your mob number
