May 17, 20251 yr Hi I'm having problems with the carbs that I have on my 1991 xj 600 when stripping the carbs to put them in a ultra sonic cleaner one of the carb body's cracked. Now I'm having problems getting a replacement set could I fit a different set of carbs from a different model bike
May 17, 20251 yr Moderator What is your exact model of bike?3KM5 999A3KM5 999B3KM6 999A3KM6 999B3KN3 999A3KN3 999BEdit/Actually, ignore all that, it doesn't seem to matter...Yamaha XJ600 (3KM5, 1991) 999 A 1991 CARBURETOR supplied next day (UK only) by Fowlers PartsWhich carb was it from that diagram?
May 30, 20251 yr Moderator I may have an old set from a burned out bike, bodies might be ok.I'm away atm and back sunday evening but off work next week if you want me to look
June 1, 20251 yr Author Hi drewpythat would be great if you have some carb bodies I'm mainly after the number three carb body as its cracked.
June 3, 20251 yr Moderator On 01/06/2025 at 20:23, mozpdragon said:Hi drewpythat would be great if you have some carb bodies I'm mainly after the number three carb body as its cracked.ok, let me have a gander. weathers been shite atm
June 20, 2025Jun 20 Moderator i PM'd you ages ago and thought you were sorted.I took photos and just need to WhatsApp the photos if you PM your mob number
