Posted November 26, 200618 yr When riding my R1, sometimes at low or high speed there is a snatch in second gear only, is it a common fault or does it need a new gearbox? Any ideas?
November 30, 200618 yr When riding my R1, sometimes at low or high speed there is a snatch in second gear only, is it a common fault or does it need a new gearbox? Any ideas? When you say snatches..... do you mean it jumps out of gear? If so sounds like second gear has given up or on its way out. Does the bike get wheelied?
December 4, 200618 yr Author When you say snatches..... do you mean it jumps out of gear? If so sounds like second gear has given up or on its way out. Does the bike get wheelied? It does jump but still stays in second gear, not done it since oil level has dropped down may have overfilled it, thanks anyway.
