sussies
can anyone out there let me know factory settings for 1996 yzf 750 front,rear suspension settings,preload,rebound + compression i'v no owners manual thanks
Hi Willy, i have a manual for the yzf 750 somewhere, i'll try to find it and give you the settings.
HI ,FOUND MY MANUAL i'll give you all the factory settings as stated in it.
FRONT SPRING PRE LOAD = 4 th.
FRONT REBOUND DAMPING = 4 OR 5.
FRONT COMPRESSION DAMPING = 7.
REAR SPRING PRE LOAD = 3.
REAR REBOUND DAMPING = 9 CLICKS OUT.
REAR COMPRESSION DAMPING = 10 CLICKS OUT
I HOPE THAT HELPS. TONY
thanks tony i'l have a play this wekend :)
