Posted November 8, 200618 yr My 600n 1997 is leaking from a tube near the centre stand, I topped up the oil on Sunday. It was just below upper level marker when I had finished. Took it out a run and filled up with petrol. When I went to leave the petrol station there was a large amount of oil under the bike. Now 3 days later it is still coming out, and the window shows only half full of oil. Any one shed some light on this for me. Thanks Paul
November 8, 200618 yr Hi Paul Are you sure that it's oil. That's what I thought with my '97 600S - coming from a little pipe that hangs down on the right hand side near the centre stand. That's the air cleaner drain hose. I was advised to take off the air cleaner and thoroughly clean it all out, including the drain hose and that little filter thing that sits half way down it. Hope this helps Tony
November 8, 200618 yr Hi, Divvy's are prone to this, check out the Divvy forum here for a fuller answer. This is one thread on the subject... here Andy
November 9, 200618 yr Author Hi, and thanks i will look at the filter and thanks for the link, very helpfull Paul
