November 5, 200619 yr who uses what oil for thundercat??? i was told not to bother with fully synthetic unless you plan on changing oil every couple of weeks!! Is the semi-synthetic the way to go? just wondering whats the best stuff to add to my purring machine! thanks.
November 6, 200619 yr When I use to have mine, it was always serviced by the dealer and they always used Mobil1 for bikes, I travelled at least 1000 miles a month on it and would last between services. Remember you cannot use normal car oil i.e normal Mobil1 in a motorbike because of the wet clutch design, so make sure you get a bike specific oil.
November 6, 200619 yr Moderator CASTROL 20w/50.......been running 13 different Yams on it in the last 20 years......Never had a prob
November 6, 200619 yr Moderator I use Millers classic semi-synthetic sport 20/50 in my xs400 £29 for 5 litres, but lasts 2k miles. They also do full synth for modern bikes
November 6, 200619 yr Fully synthetic gives your engine the best protection and gives better performance than other oils. You do have to change it every 3k miles but if you want your engine to last I can't recomend it enough. I use Mobil 1 fully synthetic in my R6 and don't have any problems with it. One thing is with the Mobil 1 is the yamaha dealers can't get hold of it anymore so they have swapped to motul which is apprently what they use for Moto Gp. Regards
November 19, 200619 yr Author well i've actually put in castrol R4 Synthetic for now - so we'll see how it goes! £30 for 5 litres!!! But i suppose the protection the most important thing! regards all.
November 19, 200619 yr i use castrol in my Hornet. no problems with it. i also used it in my TZR which actually made it run better, it smoked less and didn't stink as bad.
