1992 Yamaha FJ-1200 ABS does not want to idle when hot. Splutters, misfires and dies.
On 2/17/2025 at 6:46 PM, Snakebite68 said:
If you're only just figuring that out, this must be your first bike
First bike .............. tsk, tsk, tsk 🤣  you were still in diapers when I  .......  nevermind. 😂
Don't be so sure, I'm older than I sound! 😛 lol
Where as.....I'm older than I look!!😂
I used to be older than I looked, but then I got fat and bald! rofl
Right then, I now know why a bike shop doesn't want to put a 4-barra carb back on a bike.
I literally had to stop a few times and walk away to prevent things flying through the garage or breaking something on the carb or bike. I wish I could light a fag or something but gave that up 5 years ago. Enough frustration to start again tho.
Putting the throttle cables back on for a start, keeping various vacuum hoses connected and where they are supposed to go, and then the 'piece de resistence' lifting the rear subframe back in place while trying to fit the air box boots on the back of the carbs.
My paws are way to big to fit in all those nooks and crannies to make everything go back to where it is supposed to be.
BUT, I got there in the end, didn't break anything and haven't got any bolts or nuts left.
BUT you wanna know the punch line from this saga ........ took it for a test drive. I does run like a sewing machine and smoother than it did before ...... came back and parked it in the garage and left It running on idle ....... SPLUTTER, PFFFT, SPLUTTER PPPPPFT, SPLUTTER, BANG, PFFFT ... 🤮
Still got the bloody missfire on 2
Valve clearances next I guess. 😪
It's always nice when you don't have any spares! :D
Thought that was going to be a happy ending!! 🤣
  • 3 weeks later...
F*ck no, it gets worse.
So my one-man-band guy in his garage is pretty swamped at the moment so he said try this other shop, a bit further away, and tell them I sent you. They have a bigger shop, more staff, and they are pretty good.
Soooooo, I contact them, told them the bike's life story up until now and what we replaced and tried to achieve.
Guy says ..... I'm not going to fix someone else's problems only for you not to return ...... so you can F8ck off. (not in those same words but you get the gist 😱)
I am seldom lost for words but ..........
back to my guy I guess but it won't be quick.
I'm not normally a 'name & shame' person, but that's terrible!
And I'm not sure on our rules for that either... So probably better not to.
But the point is, it doesn't matter how many people have 'had a go' with it, it's work, and if he can fix it, it just shows his skills.
What I'm reading out of that is: "I'm not a proper mechanic, am crap at diagnostics and can only swap out parts hoping the problem will go away." (which is partly what you've been doing, but he's supposed to be the professional!).
My guy already agreed to take the bike in and swap tyres, that I bought and are in his tyre rack, and then do a pressure test.
Then I'm sure I can talk him into valve clearances if that needs doing. I just have to be patient.
Weather was lovely last few days. Drove it to work, morning is fine, afternoon filtering through traffic on the way back and timing the traffic lights, so I can keep going, things are not too bad. Never knew there was a thing like traffic light idling anxiety 😉
  • Admin
Wow that's shocking, obv he doens't need new customers.
  • 2 months later...
Right then gents, I guess you've all been waiting to see if you were going to hear from your resident Cloggy again.
New tyres went on 3 weeks ago and new fork seals at my regular guy. Still unhappily spluttering my way through Cornwall.
But the saga continues :
Told him not to waste time on compression test because I found a friendly Kawa garage with big showroom and 3 or 4 mechanics that were willing to take it in and do the valve clearance and have a look what else they could see what was going on. By all accounts a pretty professional looking set-up.
She was booked in for 13th May, and was going to take about 3 hours @ 75 quid/hr. One of the boys had, i was assured, experience with working on these (Yam) bikes. So booked in 2 weeks in advance and brought over close of play on 12th.
The 13th came and went because they needed a special tool. The special tool came but was the wrong special tool. So they ordered a new special tool. All in all this took till last Thursday when I picked it up. I was assured it would be soooooo much better............................... it wasn't. I thought it was slightly worse. So thanks for the 315 Quid but no thanks.
So where are we now : Coils, caps & plugs : £550, Carbs rebuild £275, valve clearance £315.
I feel that I have only gone backwards and NO so-called bike mechanic has got a fookin clue what he is looking at.
I called the garage on Monday and had a chat with the mechanic that worked on it. He only test drove it for minutes rather than the 20 mins it needs to reveal the real issues, so they simply do not listen when you describe your issues.
Then a little light bulb moment : He said he took off the ignition pick up cover at the left hand side to set top-dead-center and saw there was some araldite glue or something holding something together but didn't give it any thought because he was focussed on the valves.
Hmmmm a bit of glue on something ...................... really !!!!!
This is a previous owners garage' bodge for sure. Some people need shooting.
<a data-flickr-embed="true" href="Yam pickup" title="Yam pickup"><img src="https://live.staticflickr.com/65535/54563504044_0d83a74156_b.jpg" width="768" height="1024" alt="Yam pickup"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
New second hand one :
<a data-flickr-embed="true" href="Yam pickup2" title="Yam pickup2"><img src="https://live.staticflickr.com/65535/54563503879_f37ca78451_z.jpg" width="576" height="428" alt="Yam pickup2"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
I think I have found my smoking gun.
Edited by DutchFJ1200
right/left wrong
What in hell is that??? lol
That's a metal part is it not? Is it actually snapped?
Have you noticed that there appears to be a tab snapped off the domed disk in front of it too?
I do not know what the rock hard blob is but it must be hiding the ignition pick up in there somewhere that obviously overheats or expands beyond ignition parameters/settings when the engine reaches operating temperature.
The rotor indeed shows some damage but all the tabs are there.
There is some same goop at the bottom of the aluminium casing as well like that broke away too and has been repaired.
Rotor from ebay
<a data-flickr-embed="true" href="Rotor" title="Rotor"><img src="https://live.staticflickr.com/65535/54563482416_e3ff83d874.jpg" width="478" height="337" alt="Rotor"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
I have updates ...... the damn thing is FIXED !!!!!! 🤗🤗
I ordered 3 things last week. A magnetic pick-up sensor with wire & plug only in Poland, a rotor in UK and a back plate with sensor and wire complete in Holland.
The Polish magnetic sensor & wire only arrived yesterday and I was ready to take hammer & chisel to the blob only to find it crumbled at the lightest touch. Some dick had 'glued' the sensor on with window putty or badly mixed epoxy.
Clean up, install new sensor, lead wire and plug behind the heat shield to the other side of the bike and plug into the loom.
The bike ran smooth today and stationary at traffic lights quietly rumbles on tick over, no drama.
I treated her to an oil change and a chain lube just now and all is good in Yamaha FJ1200 world.
Thanks for bearing with me, your suggestions and commiserations 👏
YEY!!!
So what about the bit at the bottom of the casing that appears to have the same stuff on it (I think it looks like putty too)?
55 minutes ago, Snakebite68 said:
YEY!!!
Seeing the damage in there and on the ali casing I can only think that some object got flicked up by the front tyre and smashed its way into the casing.
Now that the bike is happy again I may take the cover off one of these days and revisit that with some Belzona liquid metal.
For now I must have the healthiest 33 y/o FJ1200 on the planet with new coils,leads,caps,plugs, refurbed carbs and adjusted valve clearances 🤣
Well, at least it's fixed! lol
So Roger the Bodger was a previous owner of the bike!! Whilst his putty job got it going it didn't fix it.....then you bought it!....and now the Wallet Emptying Barsteward is finally fixed. Congratulations. Well done that man. You deserve a medal for perseverance............medal....medal!! says Mutley 👍👍
