YZF750R 6-speed Transmission
Greetings. I hope someone out there can assist. Does anyone have the gear ratios for the YZF750R 6-speed transmission?
I actually have two YZF1000R engines, one with the standard 5-speed, the other with the 6-speed from the YZF750R.
While I'm looking for the ratios for all gears, the final gear (6th) is the most important as I am trying to calculate top speed when using different gearing combinations on the rear end, and without the gear ratio data I am stuck.
Thanks very much in advance for the assist.
John
I will try and remember to get these for you first thing in the morning B)
That would be great. Thanks very much!
John
YZF750R Gear Ratios
Gear Ratios (no. of teeth)
Primary Reduction 1.896 to 1 (91/48T)
Final Reduction 2.688 to 1 (43/16T)
1st 2.571 to 1 (36/14T)
2nd 1.941 to 1 (33/17T)
3rd 1.556 to 1 (28/18T)
4th 1.368 to 1 (26/19T)
5th 1.217 to 1 (28/23T)
6th 1.083 to 1 (26/24T)
Shaft runout (max) 0.08mm
Thanks very much!
Now I can go and do the math. :)
Best Regards,
John
  • 16 years later...
Here's a piece of thread necromancy...
So, to add to this thread, I have a different question:
1/ Is the 750s 6 speed gearing strong enough to handle the 1000r?
2/ Bearing in mind that the above numbers supplied by Alex mean ABSOLUTELY NOTHING to me, how does the 6 speed box compare to the 5 in the lower gears? Does it gain or lose acceleration (because let's face it, acceleration is what the Ace is all about!)?
