November 2, 200619 yr Greetings. I hope someone out there can assist. Does anyone have the gear ratios for the YZF750R 6-speed transmission? I actually have two YZF1000R engines, one with the standard 5-speed, the other with the 6-speed from the YZF750R. While I'm looking for the ratios for all gears, the final gear (6th) is the most important as I am trying to calculate top speed when using different gearing combinations on the rear end, and without the gear ratio data I am stuck. Thanks very much in advance for the assist. John
November 6, 200619 yr Admin YZF750R Gear Ratios Gear Ratios (no. of teeth) Primary Reduction 1.896 to 1 (91/48T) Final Reduction 2.688 to 1 (43/16T) 1st 2.571 to 1 (36/14T) 2nd 1.941 to 1 (33/17T) 3rd 1.556 to 1 (28/18T) 4th 1.368 to 1 (26/19T) 5th 1.217 to 1 (28/23T) 6th 1.083 to 1 (26/24T) Shaft runout (max) 0.08mm
April 7, 20232 yr Moderator Here's a piece of thread necromancy... So, to add to this thread, I have a different question: 1/ Is the 750s 6 speed gearing strong enough to handle the 1000r? 2/ Bearing in mind that the above numbers supplied by Alex mean ABSOLUTELY NOTHING to me, how does the 6 speed box compare to the 5 in the lower gears? Does it gain or lose acceleration (because let's face it, acceleration is what the Ace is all about!)?
