November 3, 200619 yr do u know how to get the badge of an rxs pannle with out damaging the bagde Get a hair drier warm the badge up and pull off when it is really nice and hot. Dont try to force it though. To remove the remaining tape use a light solvent like nail varnish remover. As simple as that enless the badge is pinned on aswell which means there will be a hole where the badge was. You will have to take this to a paintshop to get them to fill it prime and paint it. Hope this helps Robbie
November 4, 200619 yr Author Get a hair drier warm the badge up and pull off when it is really nice and hot. Dont try to force it though. To remove the remaining tape use a light solvent like nail varnish remover. As simple as that enless the badge is pinned on aswell which means there will be a hole where the badge was. You will have to take this to a paintshop to get them to fill it prime and paint it. Hope this helps Robbie cheers it dose a bit lol
November 4, 200619 yr Good to hear. I made the mistake of helpinfg my mate de-badge his vauxhall vectra. The vauxhall badge was pinned on so ended up spraying half the boot lid to get rid of the offending hole. He then took the other badges off and damaged the laquer, meaning I had to do the rest of the boot. Regards
