What do I need to lube and how do I do it?
Just got a 1979 XS400F and I am trying to do some general maintenance. I changed the oil, oil filter, and plugs and tightened every nut and bolt I could find. Now for my questions about lubing:
What do I need to lube?
How do you lube it? - Specifically, the cables.
How often should I lube it?
The bike seems to be running well so I don't really want to mess with it too much, but are there any other general maintenace procedures that I should look into? Thanks.
chain weekly and after rain use
cables annually/3000miles
i spray ACF (wd40 but better) on plastics (except side panels, rear seat and tank) carb bodies and any exposed alloy
hinges etc annually
steering bearings depends on tapered or original, usually 6000 miles
