XJ900F 58L TCI compatible with XJ900F 31A?
I have a malfunctioning 31A TCI unit. The only affordable and available TCI is a 58L type. Is there any downside on using that newer TCI? Can it harm? I can't find any differences except this:
HCP418
OEM TCI Ignitor Unit
oem part # 31A-82305-10-00
small black label lettered:
TYPE TID14-19
31A-10 (date code)
3 + 6 terminals
Advance curve:
5* +/- 1* at 1050 rpms
7* at 1600 +/- 225 rpms
30* at 2900 +/- 300 rpms
33.5* +/- 2* at 3500 rpms
38.5* +/- 2* at 6000 rpms
39.5* +/- 2* at 6000 rpms
40* at 5500 rpms
36* at 9000 rpms
Application:
XJ900RK, RL
HCP11857
oem part # 58L-82305-10-00
small yellow/golden label lettered:
TYPE TID14-37
58L-10 (date code)
Advance curve: unknown
Application:
XJ900 N, FN, F
I hope someone can shine more light on this.
Regards,
Martin
Edited by pdahazzard
additional information
Solved by NE0
Go to solution
hi there, I found the very same data on this website:- https://xjbikes.com/forums/threads/extra-tci-uniits.40084/page-2
which i assume you copied and pasted it from as its in the same format.
You ask if there's any downside and can it harm?
Well, reading the rest of the thread on the XJbikes forum, member K-Moe writes in to explain : ( copied and pasted across)
The advance is telling you when the spark fires in degrees of crank rotation before TDC. Having the wrong advance curve will definitely affect how well the engine runs as spark advance is dependent on the valve timing of the engine. While it is possible to run with spark timing that is different than stock (sometimes it's preferable, depending on the engine), if you get too far off the engine will run very poorly.
and it would appear that the advance curve is unknown for the 11857, therefore its also unknown how it would perform in place of the OEM 418.  I'd venture to say without that information it would be one of those trial and error situations, i.e give it a go , it may or may not work. However, in view of there being two available, one for the XJ900RK and RL with a different one being listed for XJ900N etc implies there is likely a difference  and you may well notice it when fitted.
I also noted that on page 1 on the thread there was also a post on testing and repairing TCI units.
Good luck, let us know how you get on.
  • Solution
Another option for you martin is to get yours repaired and your 31A-10 is listed here.
https://uk.carmo-electronics.com/repair/ecu-tci-cdi-box/caru-ya-xj900f-spark-unit-tid14-37-58l-10-tid14-19-31a-10?___store=carmouk_store_en&___from_store=base_store_en
ahhh, this might be of interest....
There is a company in Oz that lists a replacement for your TID14-19 (31A-10)
https://www.ecureplacement.com.au/ecu-product/yamaha-xj900rk-seca-tid14-19-ecu-replacement/
and a different listing for the TID14-37 (58L-10)
https://www.cdireplacement.com/cdi-products/yamaha-xj900-tid14-37-cdi-replacement/
However, they are both the same price and it may be the same unit? I note the model number listed 000.299.000 S120 45 is the same on both entries.
I can see its not cheap, but it may be useful in finding one closer to home
or an email to them might be useful to you.
I applied the 58L TCI on my 31A bike and it runs flawless! It feels like I should have done this years earlier, but why should you, when it is not broken?
For anyone in doubt to apply a 58L TCI on a 31A: Don’t hesitate!
Thanks for your insights,
Best regards,
Martin
Best regards,
