May 12, 20233 yr Ybr 125 59 plate kirk starts first time.but the electric start won't work unless it's been ran.And then the electric start works. Leave bike over night and will.only start with kkick.start again Any advice at all would he very much appreciated
May 12, 20233 yr Moderator I assume it WILL actually turn the bike over? Sounds like you have either a weak starter or a weak battery...
May 12, 20233 yr Author It does turn the bike over yes. Sorry should of said that in the post. Battery is brand new it kicks up first time and once the bikes been on a run the button works as it should. But once left over night it just won't start the bike in the morning so has to be kick started again. Thanks for your reply
May 13, 20233 yr Moderator Sounds to me like a weak starter then. But I have no doubt someone more knowledgeable will be along shortly to tell you the real reason! lol
