February 19, 20233 yr I've finally got my YA6 running. Took it for it test run. My transmission shift pattern is Neutral 1, 2, 3, 4 down. Is the correct? It shifts fine. I can't find any documentation about this. Thanks
February 19, 20233 yr Hi there, Ok I found this. It might be of some use to you, it seems to be an online copy of the SERVICE MANUAL for you bike. I did look for shifter position but it has hundreds of pages so that bit will be down to you to look for. Hope this helps. http://www.yamaparts.com/2013/01/engine-service-manual/
February 19, 20233 yr Moderator I'm not certain what your actual question is... If you're asking if your YA6 only has 4 gears: Correct If you're asking if your YA6 is N and 4 down: Appears to be also correct. You've got a toe and heal gear shifter on it haven't you? Past that, if it works through all 4 gears nicely, don't worry about it...
