YA6 Shifter Pattern Confirmation
I've finally got my YA6 running. Took it for it test run. My transmission shift pattern is Neutral 1, 2, 3, 4 down. Is the correct? It shifts fine. I can't find any documentation about this. Thanks
Hi there, Ok I found this. It might be of some use to you, it seems to be an online copy of the SERVICE MANUAL for you bike. I did look for shifter position but it has hundreds of pages so that bit will be down to you to look for. Hope this helps.
http://www.yamaparts.com/2013/01/engine-service-manual/
I'm not certain what your actual question is...
If you're asking if your YA6 only has 4 gears: Correct
If you're asking if your YA6 is N and 4 down: Appears to be also correct.
You've got a toe and heal gear shifter on it haven't you?
Past that, if it works through all 4 gears nicely, don't worry about it...
