Hi All, I've recently suffered a mid life crisis and bought a 1985 RS200 similar to the one I owned back when I was younger/happier.
The bike is in very good condition overall, apart from the exhausts blowing slightly between the downpipes and and the silencers.
I took off the silencers and found there were no gaskets between the downpipes and the silencers, which explains them blowing.
I've spent hours online trying to find the gaskets but no luck so far. I phoned Fowlers Parts who were kind enough to dig out the microfiche for my model, but apparently the original gaskets have been discontinued.
If anybody has any idea what I could use as replacement gaskets for the discontinued ones I'd be really grateful.
Thanks, Stuart
hi there and welcome.
The trouble will always be finding new old stock of parts for bikes (and cars) which are not only nearly 40 years old but also of relatively low production models.
I assume you are referring to the silencer to downpipe sleeve gasket? have you got an idea what shape it is from the parts catalogue  or is it a ring gasket?
If you have the yamaha part number, then the website Cmsnl.com have the facility to list which other bikes the part number shares, you could then look up parts for those bikes to see if you can find one which is available for another yamaha bike.
Having some measurements will help, the inside diameter of the silencer and the outside diameter of the inserting downpipe is a good start.
An alternative to consider is a universal graphite sleeve Silencer gasket that may be suitable?  such as Ebay item  number:204064690445 which has a 38mm ID 45mm OD.
Alternativley look up other makes of bike on Ebay which also have a graphite sleeve gasket for the rear silencer and look at the sizes to see if you can get one to fit.
My Honda 400/4 has one , and is readily available for example and a look on ebay shows its size 32 x  37.5. and that happens to be the same size as a Honda VFR700...and its cheaper!
Hopefully that info may help.
Edited by NE0
Hi Neo, thanks for replying so promptly.
The gaskets were missing from the silencers so I have no idea what they look like, and I didn't think to ask Fowlers for the parat number at the time, I think I'll give them a buzz on Monday and ask if they'd be kind enough to give me the part number.
It's a good idea to measure the inner and outer diameters of the downpipe and silencer and look for a similar size gasket from another bike. I guess the RS100 and YB100 models would be a good starting point.
Straight after tea I'll be down the garage to dig out my vernier gauge...
Thanks again, all the best
Stuart
you're welcome,
YB100 models theres an exhaust gasket for sale on ebay now, might be worth looking at,(gives the part numbers ) ask the seller for the size of it?
https://www.ebay.co.uk/itm/394289575664?epid=599715896&hash=item5bcd7d76f0:g:R38AAOSwpitjSt4X&amdata=enc%3AAQAHAAAAoFewe7d%2BAvrPC1VTxLGpHJNdHyTvy6FlXEAGAPANnNXjGKKLL2FBEki5jTuKxmj13G7YaN19DmYbujOCpMYQxzSTXEP4vLaR5yf4VdzvRbwAX4cufssVArAi79MTkFGIP330eicT1O%2BSK7B0CDzzus0eluL7RGhc5ajZnJFzjLfq7uM8Iv0l%2Fgs6OCnFSFBtGS9FoVOySICaaVrx16RNiOI%3D|tkp%3ABk9SR8bZjL-aYQ
this link
https://www.ebay.com/p/1737220622?iid=372598027432
is the same part number which is compatible with the RD200.
have a look at the picture.
Also....If for example it's the same size as a Honda one but the Honda is too long, a fine hacksaw could make two from one!!!
Edited by NE0
Hi Neo, I checked the outer diameter of the downpipes and the inner diameter of the silencers and there's only a millimetre  or so difference between them so I don't think that it can be a teflon ring type gasket now.
While I was measuring the silencers I noticed that the suffix code for the offside exhaust is 3L2, which is Yamaha RS200, but the suffix code on the nearside exhaust is 1E8, which apparently is for the RD200!
I'm going to look for more info now on how the RD200 silencer gaskets fit to the downpipes.
Cheers, Stuart
Stuart, most 70's and 80's bikes had sleeve gaskets that fit over the downpipe and they are not very thick, and the silencer then fits over the whole lot, clamped into position.  I'd venture to say that theres a good chance they used the same gasket for many of these similar bikes. It wouldn't surprise me if you said the RD200 gasket and RS200 are the same , and it wouldn't come as surprise to learn it was the 3NA-14714-01 !!
if you click on that link above/below
.https://www.ebay.com/p/1737220622?iid=372598027432
clicking on the picture gives a nice exploded view.
For the price bud, I'd buy one anyway just to see if it fits!
Edited by NE0
What sizes did you get when you meaured the downpipe and silencer Stuart?
Ive looked up this part number 3NA-14714-01 and  its OD 1 1/2" ID 1 1/4" 5/16" wide. (39mm x 31mm x 8mm wide and found that it supersedes the following part numbers :
132-14714-00, 132-14714-01, 3NA-14714-00, 3T5-14714-00, 4YYE-4714-00 and fits many bikes but the RS200 is not listed amongst them. ....but if the size is right??
1963 YG1
1966 YG1T
1966 YG1TK
1966 YL1
1967 YL1E
1967 YL2
1967 YL2C
1968 YCS1
1968 YCS1C
1968 YLCM
1971 CS3B
1971 CS3C
1973 RD60
1974 RD200A
1974 RD60A
1975 RD200B
1975 RD60B E
1976 LB802AC
1976 LB80IIHC
1976 RD125C
1976 RD200C
1977 LB802AD
1977 LB80_3D
1978 LB50PE
1978 LB802AE
1979 LB50PF
1980 LB50PG
1975 RS100B
1976 RS100C
1975 RD125B
Edited by NE0
Hi Neo, I  measured the outer downpipe diameter and inner silencer diameter and they were both 35.5 millimetres.
It's almost an interference fit pushing the downpipe into the silencer, but as there were no gaskets in the the silencers I guess the build up of soot and carbon in the silencer necks has narrowed the bores slightly?
I need to scrape out the inside of the silencers tomorrow and measure them again, I'll let you know the measurements after cleaning.
Thanks again, Stuart
Just been browsing the net for the past hour or so for you.
indeed 3L2 is the RS200 dating from 1980, can't find an online parts catalogue for it or pdf parts manual.( takes someone who has a copy and interest to have uploaded it in the past and still be sitting on a server somewhere!! )
Looked on ebay of course, including the 'sold and completed' items and didn't find anything either. Occasionally a microfiche becomes available (i've bought some in the past) these were often the only source of information for all products as it was a very popular format back in the 70's 80's. You don't need the official microfiche  station to view them, I remember having one at work, but you can read them with an eye loupe and bright background light. Sometimes you have to get these sort of things if you run an older vehicle.  So if a microfiche becomes available it might be worth buying one.
The picture of the 3NA gasket shows a compressible cone gasket, these fit into a cup like structure on the silencer or just inside, and the castlelated lock nut compresses the gasket around the downpipe.
If the downpipe and silencer are similar size then the gasket might be a ring one, Often a soft asbestos like ring which fits down inside the silencer onto an inside lip, the downpipe slides in and is pushed into the soft material making a gastight fit. I've seen bikes in the past that used this arrangement.
An acceptable alternative (and may be a solution for you) is exhaust paste:  smeared onto the lip inside the silencer and the downpipe pushed into it. The exhaust heat cures it and it goes rock hard. Seals the joint but  it can be difficult to remove.
Having said that, sometimes it's not as good as it sounds and always cracks up and starts blowing again and you end up repeating the process on a weekly basis!!!....which is why they invented exhaust joint tape!! and you'd wrap this unsightly silver bandage/tape around the joint, it would cure with the heat, go rock hard, enough to get it through the MOT and then fail a few days later!!
But by far the best solution, would be to use the proper gasket, like I said earlier, you may end up using something for another model or indeed another make of bike. It's all down to knowing what it looks like and how big it is. The part number will really help you.
Edited by NE0
Hi Neo, thanks very much for your research, it's much appreciated.
I scraped the soot from the neck of one of the exhausts but it hardly made any difference to the diameter measurements, and I couldn't really feel much of a step inside the neck either so I'm not sure that a ring type gasket fits inside.
I've used exhaust paste in the past to seal exhaust joints, but as you say it can be a real pain to seperate them again. A friend has suggested smearing Blue Hylomar on the downpipes before pushing the downpipes into the silencers. it doesn't harden and it copes with high temperatures. If it doesn't do the job at least it won't be a problem seperating the pipes again to clean it off.
I hadn't thought about looking for a microfiche for the RS200 as I don't have access to a reader, but after you mentioned being able to read them using a loupe and a strong light I thought I'd have a look.
I've now found and bought a microfiche for the RS200 from Germany. it's for a 1980 model, but has the 3L2 suffix so hopefully there won't have been too many model changes during the production run, besides it was only 11 quid so it hasn't broken the bank. As you've mentioned, once I have a part number I can start doing comparisons with other models.
Thanks a million for all your help. You've pointed me in other directions that I hadn't thought about, hopefully one of them will lead me to a successful conclusion!
All the best, Stuart
You're welcome stuart,
I've got a couple of eye loupes one is 20x  and  16x and I think the other x2, but I must confess I've no idea where the 20x one is!!!, I've just looked and its not where I thought it was!
None of them are big, hopefully I won't have a buy a magnifying glass to find it🤣
Although I have both my BIkes on Microfiche, I also bought the parts books  when I found them, so the microfiche is just of historical interest and forms part of  small collection of literature I've collected over the years on my bikes.
I've also given you a few thanks and now you've got a Gold place on the Leaderboard!👍👍
Edited by NE0
Thanks for this Neo.
Funnily enough I have read another article from Steve Cooper on the RS200, dated the 2nd of July 2022, but this one is slightly different from his last one.
I'm not complaining, the more information I can get my hands on the better!
You're welcome Stuart
However, I'm slightly intrigued by your name!....have you more than one bike?
Your name is RS100 Dave....not RS200 Stuart? 🤔😆
Ah, Well spotted Neo.
A mate of mine (Dave), after 20 years without a bike was looking for a cheap way to get back on two wheels.
I had a rusty old 1978 RS100 that had sat at the back of my garage since 1992 when I'd bought it to help an ex-girlfriend learn to ride, so I ended up selling it to him as a project for a few quid. I've been riding 4 stroke 4 cylinder bikes for donkeys years, there was no way I would ever go back to 2 stroke screamers.
Unsurprisingly the RS100 needed a bit of work doing to it after 30 years of sitting around the garage, and as Dave isn't too hot on using the interweb I joined Yamahaclub.com on his behalf in case he needed any help and advice during his restoration.
Eventually we got the RS100 back on the road and Dave started coming out on weekend runs with us.
I had a couple of goes on it myself while we were out and about. I'd fotrgotten how much fun a small buzzy smokey 2 stroke could be...
Within a few months I was scouring ebay for a small 2  stroke for myself, and I ended up buying a good condition RS200 the same colour as the one I'd owned  back in the eighties.
It didn't seem worth the hassle of changing the membership details,  which is why I'm now Yamaha RS200 Stuart with a handle of Yamaha RS100 Dave
If I had just restored the RS100 myself in the first place, instead of selling it to Dave, I'd have saved myself a  bundle of cash :(
