Female connector/crimps
Long shot. Does anyone know the type style of connector (female) for the 5VK8195041 relay from an R1? Its a 16 pin. The existing one appears unmarked.
Hi Gingerchili,
Are you referring to the name of the connection? as in:-  "D connector" where "D" is the physical shape, "JST connector." (japanese Solderless Terminals). DIN connector (Deutsches Institut für Normung) connector. The List goes on and on....
The connectors listed above have one thing in common....they, at the time, have been 'standardised' .As in manufacturers making something to a standard across the industry so that their parts become compatible.
However, Relays and the like have numerous pin outs, depending on the internal circuits of the relay etc, 10 pin , 12 pin, 18 pin etc, They subesquently have the pins grouped together in various box shaped sections, they may well have a name used by the manufacturer, but its not a term commonly used for its sales potential. So they tend to be referred to by 'gender' ,from the plug or socket, such as a 12 pin male or 16 pin female etc. (Molex was/is a brand name of common vehicle connector)
Quite a few years ago I dabbled with electronics and made a few bits and pieces, but I never came across a common name for relay and other black box components in their detailed catalogues, other than by brand name /pin out and gender.
Hope that's of some help.
Edited by NE0
Hi again,
just re-read your post.
Are you trying to source the  actual connector on the loom? (which plugs into your relay)
OR
Are you trying to find an alternative relay with an identical pin out to replace your R1 version.
You may have to contact Yamaha.
