  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
SR125 Starting Problem
Hi Everyone,
Bought an old SR125 project that had been off the road. Long story short, it's just about having my lifeย ๐Ÿ˜‚ย with not starting.
It's got good compression, got fuel, got spark (possible issue) and everything else seems good. I have bare bone wired it, to cut out out the sidestand, neutral and relays but no difference.
Bike cranks but won't catch, it gets spark but seems strong first fire then not so strong. Battery is good and new so ruled that out. Pick up coils are good.
Soooo I keep coming back to the CDI unit but I they are like hen's teeth. Could the CDI be bad but still giving a spark.
Anyone used an aftermarket CDI unit?
  • 7 months later...
Hi,
Assuming your carb fuel pipes are all good, have you checked the pilot jet screw in the carb is set correctly? Maybe lean or flooding.ย
  2. Tap Permissions โ†’ Notifications.
