XVS950 frame clearance
Hello,
Anyone know or can obtain the clearance in cm from the ground to the under frame.
I'm planning on using a car jack and a wide steel plate to place up to the engine frame and then raise for servicing etc.
Wondering if i need a low profile jack or whether standard is OK
Kev
Google is your friend...
Ground Clearance: 5.7 in OR 145 mm
